Se da navigatia Magneti Marelli seria 9663291777,vers.soft 6.62,fabricata la 07.01.2007
Navigatia trebuie configurata pentru VF36DRHRH2109XXXX,Rpo/dam 10168 .
Caracteristicile vehiculului VF36DRHRH2109XXXX,Rpo/dam 10168
Linie de produs 407
Nr. APV/PR 10168 CJ 2 0457
Data de Inceput de Garantie 20.10.2004
NRE e2*2001/116*0297*02
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
LIGNE DE PRODUIT 407
SILHOUETTE BERLINA 4 USI
FINITION PACHET HS
MOTEUR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE MANUALA6
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE EZW - VOPSEA GRI FER
TYPE D’HABILLAGE INTĂRIEUR PIELE GRAIN CLAUDIA L019 "CY"
COULEUR DE GARNISSAGE "FT"
BOITE DE VITESSES (CARACTĂRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL
MOTEUR (TYPE) MOTOR TIP EW/DW
Caracteristici vehicul
FINITION PACHET HS
DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
Alimentare motor
DĂTECTEUR D’EAU FILTRE À GAZOLE CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DĂPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
RĂCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VARIATION PUISSANCE (MOTEUR) PUTERE STANDARD
AUTODIAGNOSTIC EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DĂPOLLUTION TECHNIQUE VĂHICULE DEPOLUARE TEHNICA VEHICUL EURO4
FILTRE À PARTICULE FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
VARIANTE ASSOCIĂE INJECTION SISTEM INJECTIE SIEMENS
FILTRE RĂSERVOIR FARA FILTRU REZERVOR
BOĂTIER PAPILLON (ADMISSION AIR MOTEUR) MODUL CLAPETA MOTORIZATA (ADMISIE AER MOTOR)
Cutie de viteze - Transmisie
COUPLE RAPPORT RAPORT PUNTE 17 X 71
STYLE ROUE ROATA QUAZAR 17 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
DIFFĂRENTIEL (BOITE) DIFERENTIAL 86
JANTE / PNEU DIMENSION ECHIPARE PNEU 17 INCI
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215X55X17 W
ROUE (TYPE) MONTARE ROATA ALIAJ 2
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATOR PIERDERE PRESIUNE PNEURI
BOITE DE VITESSES TYPE ML6C
Suspensie - directie - Franare
COLONNE DIRECTION COLOANA DE DIRECTIE CU REGLARE MANUALA
ANTIDĂVERS AVANT BARA ANTIRULIU FATA DIAMETRU 24
COURSE MĂCANISME DE DIRECTION CURSA MECANISM DE DIRECTIE 174
SUSPENSION ACTIVE FARA SUSPENSIE VARIABILA
CONTRĂLE DYNAMIQUE DE STABILITĂ CU SISTEM ESP
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
ATTACHE-REMORQUE FARA DISPOZITIV DE REMORCARE
ENJOLIVEMENT LATĂRAL (ASPECT) ELEMENTE PROTECTIE LATERALA VOPSITE IN MASA + CROMATE
ENJOLIVEMENT LATĂRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE + TREAPTA
ENJOLIVEUR ROUE (STYLE) FARA CAPAC DE ROATA
FEU D’ĂCLAIRAGE DE SEUIL LUMINA PENTRU PRAG
COMPLĂMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLĂMENTAIRE RĂTROVISEUR EXTĂRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE FARA MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR MECANISM DE STERGERE PROIECTOR
OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
ROUE DE SECOURS ROATA JANTA TABLA + PNEU STANDARD
ACCESSOIRES EXTĂRIEURS MANERE EXTERIOARE + RETROVIZOARE EXTERIOARE CULOARE CAROSERIE
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE COLORAT IN MASA + ORNAMENT INOX
VITRE (ASPECT) GEAM FUMURIU
VITRE (TYPE) PARBRIZ + GEAMURI LATERALE STRATIFICATE + LUNETA SECURIZATA
ACCÈS ET DĂMARRAGE MAINS LIBRES FARA ACCCES SI PORNIRE MAINI LIBERE
Echipament interior
ALARME ANTIVOL ALARMA PENTRU VOLUM + PERMETRU - STANDARD
ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
CEINTURE DE SĂCURITĂ ARRIÈRE CENTURI DE SIGURANTA PIROTEHNICE LATERAL SPATE CU RETRACTOR + CENTURA IN 3 PUNCTE
CLIMAT (TEMPĂRATURE AMBIANTE) TARI CU CLIMA RECE
CONDAMNATION ENFANT SIGURANTA COPIL USI SPATE CU COMANDA ELECTRICA
GRADUATION VITESSES GRADATIE IN KM/H
COTĂ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD STANDARD + FATADA DECORATIUNE LEMN
COMBINĂ (CARACTĂRISTIQUES) GRADATIE 260 KM/H 160 M/H FUNDAL NEGRU
GARNISSAGE DE PORTE DECORATIUNE LEMN
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
ISOLATION (RIDEAU, PARE-SOLEIL LATĂRAL, TOIT OUVRANT) TRANSPERANT SPATE CU COMANDA MANUALA
REHAUSSE ASSISE AVANT PASSAGER DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA ELECTRICA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA ELECTRICA SCAUN PASAGER FATA
RĂGLAGE ASSISE AVANT PASSAGER REGLARE SUPORT LOMBAR PASAGER
COMPACT DISQUE MONTARE COMPACT DISCURI
SYSTÈME DE NAVIGATION CU SISTEM DE NAVIGATIE CU ECRAN COLOR
LAMPES DE PROJECTEURS LAMPA CU DESCARCARE
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
AFFICHEUR AFISAJ (NAVIGATIE+VIDEO+RADIO+CEAS,T°,CD)
MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATEUR D’HUILE SENZOR CU FUNCTIE DUBLA NIVEL + TEMPERATURA ULEI
NAPPE CHAUFFANTE SCAUN CU INCALZIRE
SAC GONFLABLE LATĂRAL AVANT AIRBAG LATERAL ZONA TORACE FATA + SPATE + AIRBAG CORTINA
ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
PROJECTEUR CORRECTEUR ASSIETTE REGLARE AUTOMATA A PROIECTOARELOR
PROJECTEUR DIRECTIONNEL FARA PROIECTOR DIRECTIONAL
RĂCEPTEUR RADIO SISTEM RADIOTELEFON "RT3"
RĂFRIGĂRATION SISTEM DE REFRIGERARE AUTOMATA
RĂGULATEUR DE VITESSES SISTEM DE REGULARIZARE VITEZA
REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
RĂTROVISEUR INTĂRIEUR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
RĂGULATION CLIMATISATION / TEMPĂRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
TUNER-RADIO TUNER DUBLU RADIO
PROTECTION INTĂRIEURE FARA PROTECTIE INTERIOARA
DĂTECTION D’OBSTACLE DETECTOR DE OBSTACOLE SPATE
STORES LATĂRAUX TRANSPERANTE LATERALE "RAND 2"
ADAPTATION GARNITURE MANER MANETA DE VITEZE PIELE
AMPLI-ĂQUALISEUR CU AMPLIFICATOR EGALIZATOR
COMMANDE VERROUILLAGE BLOCARE PRIN SUPRA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE
SAC GONFLABLE GENOUX CONDUCTEUR AIRBAG ZONA GENUNCHI CONDUCATOR
Electricitate
ALTERNATEUR ALTERNATOR CLASA 18
BATTERIE BATERIE L3 450
DĂMARREUR DEMAROR CLASA 6+
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
FRĂQUENCE RADIO FRECVENTA RADIO ASIA
Marci echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
ROULAGE DRUM CORECT
"FRECVENTA RADIO ASIA " -se corecteaza cu diagnoza
Activarea pentru senzorii de parcare spate (vizualizare ecran) se face din BSI :
Bonus-functie prezenta la VAG daca se lasa maneta semnalizatorului cuplata ramine pozitia pe partea respectiva aprinsa.
Spor.
RT3_Telecodare
Utilizatori ce ce navighează pe acest forum: Niciun utilizator înregistrat și 32 vizitatori
- Cauta in forum
- Mesaje
- PARTENERI
- Link-uri utile
- Statistici
Total mesaje 187759
Total subiecte 18620
Posts per day: 24
Users per day: 2
Total membri 11707
Cel mai nou membru catalinos
