Electromotor BX 1.4 RE
atti_kov
Localitate: Oradea
Mesajde atti_kov » Joi 12-Apr-2007 09:59
As avea urmatoarea problema:la pornire nu cupleaza bendixul si se aude un zgomot "carait".
nicum
Masina: BX 16 RS
Mesajde nicum » Joi 12-Apr-2007 13:29
Ce electromotor ai? Se gaseste de vinzare doar comanda bendixului, ca banuiesc ca acolo e problema.
atti_kov
Localitate: Oradea
Mesajde atti_kov » Joi 12-Apr-2007 13:33
Nu stiu exact ce model , cum pot afla modelul?
nicum
Masina: BX 16 RS
Mesajde nicum » Joi 12-Apr-2007 14:37
Simplu: scrie pe el fabricantul si codul.
atti_kov
Localitate: Oradea
Electromor
Mesajde atti_kov » Joi 12-Apr-2007 16:58
Din pacate vechiul proprietar a facut modificari majore, a schimbat
cu un stator de dacie . Astept idei .
nicum
Masina: BX 16 RS
Mesajde nicum » Joi 12-Apr-2007 18:57
Atunci incearca sa pui un electromotor original. Citat din manulul de service:
Battery
Rating:
BX and BX 14 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 or 35 Ah
BX 16 and BX 19 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 33, 45 or 50 Ah
BX 16 and BX 19 with air conditioning . . . . . . . . . . . . . . . . . . . . . . . . 50 or 60 Ah
Alternator
Make . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Bosch, Ducellier, Paris-Rhone or Melco
Application:
BX and BX 14 (pre Feb 1984) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Bosch 0120 489 163 164
Ducellier 516 039
Paris-Rhone A 13 N 43
Regulator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Bosch 1 197 311 100
Ducellier 511 020
Paris-Rhone YH 1639
BX and BX 14 (from Feb 1984) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Bosch B 120 427 315
Paris-Rhone A 13 N 38
Regulator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Bosch 1 1973 11008
Starter motor
Make . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Ducellier, Paris-Rhone or Bosch
Type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Pre-engaged, 12 volt
Application:
BX and BX 14 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Ducellier 532 014
Paris-Rhone D 8 E 151
Bosch 9 000 1 42 002
Ar mai fi o idee sa repari "inventia", dar in cazul asta nu iti pot spune nimic
atti_kov
Localitate: Oradea
ref
Mesajde atti_kov » Joi 12-Apr-2007 19:12
OK. merci pt coduri , o sa incerc la dezmembrari sa vad , dar o gasesc cam greu piese la modelul meu de motor(culcat ) 1.4 .
Incerc ,pt ca ma deranjeaza "inventiile ". Multe am reparat pe "Viper-ul " meu decand l-am cumparat si am incercat sa pun piese noi .
salut , mai vorbim.
Attila
cdires
Localitate: Racari,Dambovita
Mesajde cdires » Lun 20-Aug-2007 15:53
Acolo e problema acuma la mine...
Aveti idee daca 110 RON e exagerat pentru piesa asta? Atata mi-au cerut la magazinul de piese pentru ea....
Relu
Înapoi la “Citroen BX”
    Total mesaje 187852
    Total subiecte 18700
    Total membri 11839
    Cel mai nou membru oltyboy
