are ceva daca bag ulei 20W60 la 1.9 16v
Alex 16 HSH
Mesajde Alex 16 HSH » Vin 25-Sep-2009 20:43
stie cineva daca exista probleme daca bag ulei 20W60 in loc de 10W40
abarth_mcm
Localitate: buzau-bucuresti
Mesajde abarth_mcm » Vin 25-Sep-2009 21:01
Nu ti se pare ca e cam gros 20W ? :roll: Mai ales ca vine iarna..gandeste-te si la aspectul asta..
Totusi, ce marca e uleiul si ce caracteristici are?Nivelul de performanta.
Alex 16 HSH
Mesajde Alex 16 HSH » Sâm 26-Sep-2009 11:45
Alex 16 HSH
Mesajde Alex 16 HSH » Sâm 26-Sep-2009 11:53
Alex 16 HSH
motul 300v 20W60
Mesajde Alex 16 HSH » Sâm 26-Sep-2009 11:57
We retain the right to modify the general characteristics of our products in order to offer to our customers the latest technical development.
Product specifications are not definitive from the order which is subject to our general conditions of sale and warranty. – Made in France
8258
MOTUL . 119 Bd FĂŠlix Faure - 93303 AUBERVILLIERS CEDEX - BP 94 - Tel 33 1 48 11 70 00 - FAX 33 1 48 33 28 79 . Site Web : www.motul.fr 12/03
300V Le Mans
20W-60
Racing lubricant for racing cars
100% Synthetic – Double Ester Technology
TYPE OF USE
Racing cars with atmospheric or turbocharged engines, race engines operating at very high
temperature and high rpm : race on tracks, endurance races; Le Mans 24H, rallyes, rally raid,
Paris/Dakar, dirt or ice races…
Engine producing very high fuel dilution in the oil.
Other applications : Gasoline or diesel engines, turbocharged, direct injection and catalytic converters,
vintage cars.
PERFORMANCES
STANDARDS Above existing standards.
Reference team Larbre Competition, Le Mans 24H, FIA GT...
Double Ester technology : maximum oil film resistance, balanced polarity, resistance at very high
temperature.
Friction Modifier : maximum power output, decrease operating temperature.
0% shear loss : Stable oil pressure whatever using conditions.
Maximum anti-wear resistance.
Perfect engine cleanliness.
20W-60 grade is able to absorb fuel dilution in the oil and maintains high oil pressure. Engine can run at
very high temperature.
RECOMMENDATIONS
Oil change : according to your own use.
Can be mixed with synthetic or mineral lubricants.
PROPERTIES
Viscosity grade SAE J 300 20W-60
Density à 15°C (59°F) ASTM D1298 0.888
Viscosity at 100°C (212°F) ASTM D445 22.9 mm²/s
Viscosity at 40°C (104°F) ASTM D445 170 mm²/s
Viscosity grade ASTM D2270 162
HTHS viscosity at 150°C (302°F) ASTM D4741 7.17 mPa.s
Point d’ĂŠcoulement ASTM D97 -33°C / -27°F
Flash point ASTM D92 222°C / 431°F
TBN ASTM D 2896 11.7 mg KOH/g
Mesajde mbc » Sâm 26-Sep-2009 12:57
de la a avea un GTi pana la race stuff, eu zic ca mai e. Cu ce te-a suparat actualul ulei de motor?
Later:
Ce vroiam sa zic este ca nu tii in mod normal motorul turat blana foarte mult timp in utilizarea normala, spre deosebire de curse. Verifica sa nu fie ungerea mai putin eficienta la turatii mici, comparat cu un ulei standard.
mihaistan
Localitate: Ploiesti
Mesajde mihaistan » Sâm 26-Sep-2009 13:41
cred ca singuru om care poate spune da sau ba ... este WLD :D cunoaste cel mai bine tipul acesta de motor !
Mesajde khan » Sâm 26-Sep-2009 18:42
mult prea gros, pune macar 15W50 de la Motul daca tot vrei sa faci ceva
Mesajde WLD » Sâm 26-Sep-2009 23:02
Multumesc Mihai :wink:
Alex, nu pune 20W in motor, pt ca vei distruge tachetii hidraulici si axele cu came. La pornire e prea vascos si nu ajunge sa unga axele decat dupa cateva secunde. In plus, la iarna n-o sa mai poti porni. In nici un caz sa nu pui uleiul ale carui caracteristici le-ai postat, pt ca e un produs strict racing si nu e gandit pt porniri si opriri repetate asa cum e cazul unei masini de strada.
In functie de uzura motorului pune linistit 5w40 sau 10W40. Daca mergi foarte sportiv, cu perioade lungi la peste 6000 (desi nu vad unde poti face asta in .ro) pune motul 300v 15W50.
Alex 16 HSH
Mesajde Alex 16 HSH » Dum 27-Sep-2009 17:42
va multumesc pentru lamurire
Înapoi la “Citroen BX”
    Total mesaje 187824
    Total subiecte 18667
    Total membri 11844
    Cel mai nou membru profiart
