moisina scrie:Ma puteți ajuta și pe mine cu ceva detalii pentru un C4 Coupe cu seria :VF7LA9HZH74567273
Mulțumesc!
Trimis de pe al meu VTR-L09 folosind Tapatalk
Caracteristicile vehiculului
Linie de produs C4
Nr. APV/PR 10944 88 1 0185
Data de Inceput de Garantie DDG 31.10.2006
Numar de Serie al Motorului 10 JB60 3105542
OPB I3DP
NRE e2*2001/116*0302*03
Informatii generale
GEN DE PRODUS VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU CITROEN
LINIE DE PRODUS C4
TIP CAROSERIE BERLINA 3 USI
NIVEL DE ECHIPARE EXCLUSIV VTS
MOTOR DIESEL TURBO DV6TED4 FILTRU DE PARTICULE
TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE
TIP DE VOPSEA VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI EZW - VOPSEA GRI FER
TIP ECHIPARE INTERIOARA ACCESORIU PLASA 3D XRAY + ALCANTARA "ST"
CULOARE GARNISAJ "FZ"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCD
MOTOR (TIP) MOTOR TIP DV
MONOGRAMA COMPLEMENTARA, DIVERSE VTS
Caracteristici vehicul
Alimentare motor
ALIMENTARE INJECTIE TURBO CU SCHIMBATOR DIRECT
DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
BLOC CILINDRI (MATERIAL) BLOC CILINDRI ALUMINIU
CARBURANT MOTORINA CALITATE DA/DE/DE+
DEPOLUARE (MOTOR) DEPOLLUTION MOTEUR EURO 4
CILINDREE 1600 CM3
CATALIZATOR CATALIZATOR CU 2 COMPUSI IN FILTRE IMPREGNATE CU PLATINA
RECIRE ULEI SCHIMBATOR APA/ULEI MOTOR
MOTOR RACIRE RADIATOR EP:27 - 21 DM2 ALUMINIU BRAZAT
INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
AUTODIAGNOSTICARE EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO4
FILTRU DE PARTICULE FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR 2 TURATII 130W AERO
RECUPERARE VAPORI DE BENZINA FARA SISTEM DE RECUPERARE VAPORI DE BENZINA
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE BOSCH
FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
Cutie de viteze Transmisie
CUPLU RAPORT RAPORT PUNTE 19 X 71
STIL ROATA (JANTA) ROATA RESOLFEN 17 INCI
AMBREIAJ AMBREIAJ HIDRAULIC
TIP DE CUTIE DE VITEZE (OMOLOGARE) CUTIE DE VITEZE TIP MCD
DIFERENTIAL (CUTIE) DIFERENTIAL 77
PNEURI (DIMENSIUNI, TIP) PNEU 205/50 R17 89W NERANFORSAT
ROTI MONTATE ROATA 6 INCI 1/2
ROATA (TIP) MONTARE ROATA ALIAJ 2
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE PRESIUNE PNEURI
CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
Suspensie Directie Franare
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 27
COLOANA DE DIRECTIE COLOANA DE DIRECTIE CU REGLARE MANUALA
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 22
RACIRE ULEI DE POMPA DE DIRECTIE FARA SISTEM DE RACIRE ULEI DE POMPA DE DIRECTIE
SUSPENSIE SUSPENSIE NORMALA
CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
PEDALIER (TIP) PEDALIER ALUMINIU
Caroserie Echipamente
AVERTIZOARE SISTEM DE AVERTIZARE ACORD
ANTENA ANTENA + GPS + GSM
DEFLECTOR AERODINAMIC SPATE MONTARE CU DEFLECTOR DE AER LA MIJLOCUL CAPACULUI
DECORATIUNE (VOPSEA) DECORATIUNE NEGRU STRALUCITOR
ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CULOAREA CAROSERIEI
ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ORNAMENT DE ROATA (STIL) STIL TROMPA
LUMINA DE MERS INAPOI CU 2 LUMINI PENTRU MERSUL INAPOI
LUMINA DE PRAG LUMINI DE PRAG FATA
SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
ETANSEITATE AERODINAMICA FARA GARNITURA DE CAPOTA MOTOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
ORNAMENT DE CAP DE TEAVA DE ESAPAMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
BARA DE PROTECTIE BARA DE PROTECTIE FATA SPORT IN CULOAREA CAROSERIEI GRILA BARA DE PROTECTIE SPATE STANDARD IN CULOAREA CAROSERIEI
APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
PLACA DE INMATRICULARE FARA PLACUTA DE INMATRICULARE
PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
ROATA DE REZERVA ROATA CU JANTA TABLA + PNEU CU DIMENSIUNE NESTANDARDIZATA
ACCESORII EXTERIOARE MANER EXTERIOR + COMANDA SPATE + SUPORT + RETROVIZOR IN CULOAREA CAROSERIEI
RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
GEAM (ASPECT) FUMURIU + FUMURIU INCHIS IN SPATE
GEAM (TIP) PARBRIZ IZOLAT TERMIC SI CU STRAT REFLECTORIZANT + GEAMURI LATERALE SI SPATE SECURIZATE
ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
Echipament de interior
ALARMA ANTIFURT FARA ALARMA ANTIFURT
BRICHETA BRICHETA FATA
TETIERA SPATE TETIERA SPATE REGLABILA
TETIERA FATA TETIERA FATA ARTICULATA
SCAUN SPATE PERNA SEPARABILA RABATABILA + SPATAR SEPARABIL RABATABIL
COTIERA DE SCAUN SPATE CU COTIERA SPATE
CENTURA DE SIGURANTA SPATE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
SIGURANTA COPII FARA SISTEM DE BLOCARE USA PENTRU COPIL
GRADARE VITEZE GRADATIE IN KM/H
TUROMETRU TUROMETRU DIGITAL
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
INCALZIRE ADITIONALA SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
ECHIPAMENT PLANSA DE BORD PLANSA DE BORD METALIZATA KURTZ FATADA INFERIOARA + SUPORT CREOIN VOPSITE
LUMINI INTERIOARE DIVERSE PLAFONIERA FATA 3 POZITII
TABLOU DE BORD (CARACTERISTICI) TABLOU DE BORD DIGITAL CU FATADA GRI LION
CAPITONAJ DE USA TAPITERIE USA DECORATIUNE CROM SATINAT
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA
INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 6 KG
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA PERDEA IMPOTRIVA SOARELUI
INALTARE SCAUN DE PASAGER FATA FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CONDUCATOR
REGLARE SCAUN FATA DE PASAGER FARA SUPORTURI LOMBARE SI LATERALE PASAGER
RABATERE SCAUN FATA DE CONDUCATOR CU SISTEM DE RABATERE PERNA DE SEZUT SCAUN CONDUCATOR
RABATERE SCAUN FATA DE PASAGER CU SISTEM DE RABATERE PERNA DE SEZUT SCAUN PASAGER FATA
COTIERA DE SCAUN FATA COTIERA CENTRALA
CD MONTARE COMPACT DISCURI
CASETA DE DEPOZITARE FARA CONTAINER DE DEPOZITARE
SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
BECURI DE PROIECTOR LAMPA CU DESCARCARE
ACTIONARE GEAM SPATE FARA MECANISM DE ACTIONARE GEAM SPATE
CITITOR DE INFORMATII RUTIERE FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFISAJ AFISAJ (NAVIGATIE+VIDEO+RADIO+CEAS,T°,CD)
OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATOR DE ULEI SENZOR DE NIVEL DE ULEI
MONTARE TETIERA SPATE MONTARE 3 TETIERE SPATE
FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
AIRBAG DE PASAGER AIRBAG LATERAL PASAGER
ACTIONARE GEAM ELECTRICA (FUNCTIONARE) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERULUI
PACHET ECHIPAMENT FARA PACHET ECHIPAMENT PENTRU VEHICUL DE SCOALA AUTO
RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU INCALZIRE
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
COMANDA INTERIOARA DE USA (ASPECT) COMANDA INTERIOARA USA ASPECT SOFT MISTRAL
PLANSEU SPATE INCARCARE FARA PLANSEU SPATE DE INCARCARE
PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
PROTECTIE POST FATA FARA PROTECTIE POST FATA
PARASOLAR FATA PARTE LATERALA CONDUCATOR + PASAGER FARA INSCRIPTIONARE
DEPOZITARE (POST DE CONDUCERE) COMPARTIMENT DE DEPOZITARE LATERAL CU INCHIDERE + OCHELARI
RECEPTOR RADIO SISTEM RADIOTELEFON "RT3"
REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
INALTARE SCAUN FATA DE CONDUCATOR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
COVORAS DE PODEA (ASPECT) COVORAS SUPLIMENTAR TUFTE F470 CU SNUR TEP V072
AIRBAG DE CONDUCATOR AIRBAG LATERAL CONDUCATOR
DEPOZITARE VOLUM DE INCARCARE CU PLASA + COMPARTIMENT DE DEPOZITARE AMOVIBIL IN PORTBAGAJ
COVORADS DE PODEA MOCHETA TESUTA DILOUR F550
TUNER-RADIO TUNER DUBLU RADIO
PROTECTIE INTERIOARA FARA PROTECTIE INTERIOARA
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
STORURI LATERALE FARA TRANSPERANTE LATERALE
ADAPTARE GARNITURA MANER MANETA DE VITEZA CU INSERTIE CROMATA
COVORAS DE PODEA CU COVORAS SUPLIMENTAR
AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
VOLANT VOLAN SPORT
RETROVIZOR INTERIOR SUPRAVEGHERE COPII FARA RETROVIZOR INTERIOR PENTRU SUPRAVEGHERE COPIL
Electricitate
ALTERNATOR ALTERNATOR CLASA 15
BATERIE BATERIE L3 450
DEMAROR DEMAROR CLASA 5
ILUMINAT DEOSEBIT APRINDERE AUTOMATA A LUMINILOR
MULTIPLEXARE MONTARE RETEA MULTIPLEXATA CAN CAN
Marci de echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
ATMOSFERA ATMOSFERA NORMALA
CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII
PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
SOC LATERAL USA CARE NU ESTE INTARITA
SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
RULARE DRUM CORECT
MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI + COMANDA VOLAN BUTUC FIX
TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
